1 - 10 of 10 Posts
93 celica
im in the process of swapping my 89 dx to an si. i got the motor in changed the harness over to mpfi. i gotta d16z6 IM, a b18 TB, aem fuel rail and FPR... i know i can somehow use the DX throttle cable, but i don't want to. i want to know do i need to use the si throttle cable or can i get a throttle cable from another d-series motor?
88 ED6
DPFI cable will work, no mods, just the cable is longer. GSR and/or ITR are the shortest IIRC. There's not much to throttle cables; so you just need the throttle cable itself...
93 celica
would the longer throttle cable reduce throttle response or anything? should i clean up the IM before i put it in? or should i jus "get 'er done"??
Ranger - work truck
not enough length to worry about, and cleanign it is gonna be easier now that on the car...!
88 ED6
Yup, missing the throttle bracket.
A shorter cable will look cleaner and a tad less friction depending on how you have your cable routed(with my DPFI cable, I had to make it go down and turn back towards the throttle body, effort difference wouldn't really be noticeable unless you have a very weak foot)
93 celica
good eye... i didn't even notice i was missing that.... back to the junk yards tomorrow... i gotta pick up some odds n ends.... like that bracket.... weak foot... lol
1 - 10 of 10 Posts
