1 - 1 of 1 Posts
D
The Integra cluster bolts into civics but the wires need to be re-arranged to Integra specifications and it needs to be re-fitted.
Tools Needed
1) #2 Phillips Screw Driver
2) Connectors for the 92-95 install
3) Needle Nose Pliers
4) Lots of Patients
Remove the civic cluster
Pull all the pins from the 2 civic plugs
Re-arrange them to the following specs
Install Integra cluster using swift ties or a custom bracket
ENJOY!
Now Here Comes The Tricky Part. PAY ATTENTION!!!!
for a 92-95 civic
The plugs from the EG do not fit the back of the Integra Cluster. You will either need integra plugs or EK plugs to do it.
Integra Blue Left Side Plug (13 pins)
1. BLU - Tach signal
2. GRN/ORG - Check engine indicator
3. YEL/RED - Oil pressure switch
4. -
5. WHT/BLU - Charge indicator
6. -
7. YEL/GRN - Coolant temp
8. BLK - Ground
9. RED/BLU - Cruise control (if you have cruise)
10. YEL - Hot
11. -
12. PINK - Maintenance (not used)
13. -
Integra Right Side Blue Plug (16 pins)
1. GRN/RED - E-Brake signal
2. RED/GRN - High beam
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
9. BLU/RED - ABS (not used)
10. GRN - Trunk switch
11. ORG - Vehicle speed sensor
12. -
13. BLU/WHT - Low fuel (not used)
14. YEL/WHT - Fuel gauge
15. LGT. GRN/RED - Door switch (not used)
16. RED/BLU - Seat belt
__________________________________________________
for a 96-00 civic (ITR shown)
Plug B
B1 - Yellow / Black - Seatbelt Light
B2 - Empty
B3 - Red / Blue - Fuel Gauge
B4 - Green / Yellow - 2 Silver Stripes - Low Fuel Light
B5 - Empty
B6 - Blue / White - Speedometer
B7 - Blue / Black - Trunk Light
B8 - Empty
B9 - Red - Brightness
B10 - Red / Black - Gauge Lights
B11 - Black / White - VSS
B12 - Empty
B13 - Green / Red - 1 Silver Stripe / Left Turn Signal
B14 - Green / Yellow - 1 Silver Stripe / Right Turn Signal
B15 - Red / Green - Not Available
B16 - Green / Red - 2 Silver Stripes - Emergency Brake
Plug C
C1 - Empty
C2 - Pink - Washer Fluid Level - Canada Only
C3 - Empty
C4 - Yellow - Dimmer
C5 - Empty
C6 - Empty
C7 - Black - Ground
C8 - Yellow / Green - Temperature
C9 - White / Blue - Battery
C10 - Empty
C11 - Yellow / Red - Oil Pressure
C12 - Green / Orange - Check Engine Light
C13 - Blue - Tachometer
1 - 1 of 1 Posts
