1 - 2 of 2 Posts
4
I have a mini me with a b7 block and z6 head, I never swapped out the intake manifolds but i recently did today and i came up with a missing nipple for a hose off the throttle body that anti freeze runs through. The fitting or hole on the bottom leftside of the manifold(looking under the hood) isn't even their on the z6 manifold.I just plugged the hole to bypass it so i could start the car and now i have an irratic idle. I was wondering if i could use a t fitting and connect it to another line running to the manifold right next to where it should go and if this would fix my idle?
allwheeldriveturboboxer
'08 Mazdaspeed3
i would check for vacuum leaks and make sure your iacv is getting the coolant it needs....because it is not necessary to run the coolant thru the TB...does your TB have a plate with screws on it underneath? You might have to screw in your fast idle valve, the plastic piece inside the bottom, i am assuming you have one...
1 - 2 of 2 Posts
