hey fellow d-series.org members!
i was wondering if its neccesary for the exhuast side of the turbo to be on the right of the intake side...or vis versa?
cause i mocked mine up and it fit really well with the exhaust side on the left and the intake side on the right...
lmk what you're opinions are!
thanks to all!!!
-jack
you can do it either way...but it was much easier on my car to make the downpipe fit with the exhaust un the passenger side. Look at the way the oil pan is shaped and you will see what i'm talking about
As long as you can make the exhaust bend around tight enough to miss the A/C compressor, you're good. Be sure to leave room for some kind of heat shield between the exhaust and the A/C compressor, otherwise the heat will destroy the compressor.
Craig
