1 - 18 of 18 Posts
Texas state inspection.
The 2 front side windows are not inspection item right??
Because I'm going to pull the window out before i go get inspection,as in why because is 15%dark so to be legal is 25%.
1. Horn
2. Windshield Wipers
3. Mirror
4. Steering
5. Seat Belts
6. Brakes (system) (Parking - beginning with 1960 models)
7. Tires
8. Wheel Assembly
9. Exhaust System
10. Exhaust Emission System (beginning with 1968 models)
11. Beam Indicator (beginning with 1948 models)
12. Tail Lamps (2); (1) if 1959 model or earlier
13. Stop Lamps (2); (1) if 1959 model or earlier
14. License Plate Lamp (1)
15. Rear Red Reflectors (2)
16. Turn Signal Lamps (beginning with 1960 models)
17. Head Lamps (2)
18. Motor, Serial, or Vehicle Identification Number
19. 1988 & newer - inspect for window tinting or coating
20. Gas caps on vehicles 2-24 model years old.
http://www.txdps.state.tx.us/vi/inspection/veh_class_list.asp?class=Passenger+Car
huh?
if you have no windows, how can you pass inspection?
just speak to the dps lady and she say two front side windows are not inspection item only for tinting.
endo_bobo
1998 Civic Sedan
I didn't pass for my tint in the front but it was the first and last time I ever went to that place. The normal place I go is a town over and they ask if you drove your car here then give you a sticker. Thanks Boonies.
duh
Here in NH, all original equipment must work. But some don't check everything.
Ranger - work truck
if you don't have windows they wont pass you....
it has to be present at the time of inspection....
your best bet is to roll them up and pull the fuse and PRAY they look light enough to pass, otherwise they meter them, and you fail.
and the loophole is older than 79 year model/ classified as collector-antique, then the windows can be solid black if you so choose....
Discussion Starter #13 (Edited)
are u sure????
because the lady say only for tinting meaning i don't need a window.
i fail last time when they check it with meter but i came back with out window and bitch.
when i did that they pass me,the inspector even talk to the dps.
1 - 18 of 18 Posts
