1 - 10 of 10 Posts
slipped timing belt today at a rallyx :( [timing belt covers are a good thing, mmmkay?]
So, I want to make sure that I haven't damaged any of the valves.
Should I:
a) install new t-belt, set timing, and check compression
or
b) remove head and visually check for damage
seems to me that, regardless of any visual check, I'd need to do a compression test to be 100% certain that everything's OK.
with that in mind, do I really need to do a visual check, or can I just do a compression test?
i think you need to do a leak down test to know if your valves are bent...
1990 Honda ED hatch
i would try a belt and see how it goes but 99.9 precent of honda and acura motors if they jump timing or anything like that they bend valves. but ive g0tten lucky. try a belt and go though the steps
94 civic, 90 talon
pah pah pah pah pah blurb blurb blurb blurb blurb tick tick tick tick meow meow meow meow
Basically lmao, depending on how many (I lost 2 cylinders), it wont start. lol Well I got it to crank over and run for 10 seconds when I opened the throttle some...
1 - 10 of 10 Posts
