1 - 12 of 12 Posts
del Sol si '94
Is it possible to stack 2 shims on the input shaft side get get the correct clearance?
Basically, I need a shim that is not available anymore, but I can get the clearance by adding 2 that are avail together.
del Sol si '94
Discussion Starter · #2 ·
The builder said its because I used the aftermarket bearings that came with the rebuild kit, instead of OEM. Yet again, I had to learn this lesson, always go with OEM lol
NTN is OEM, all I use.
Make sure you have the outer bearing on right, Repo-Sol didn't :)
pics and details of what you are doing before making a costly mistake.
del Sol si '94
Discussion Starter · #4 ·
Hmm, pretty sure I have NTN. Ill grab some pics in the morn.
del Sol si '94
Discussion Starter · #6 · (Edited)
Yes, hydro. 94 EX. NTN bearings.
Figured it out, didnt install the oil guide plate..... Gonna remeasure tomorrow.
Pics anyway, cause I took them lol
97 honda coupe
i wouldnt see why adding two shims would cause an issue, but obviously leaving out the snap ring would cause issues lol.
What snap ring? You're playing with the wrong shaft!
Oil guide plate has NO effect on the shim clearance, yet the shim holds it in place.
Trying to follow he FSM to guess at the shim...waste of time.
del Sol si '94
Discussion Starter · #10 ·
1996 Civic Type DX
Is he using the OEM tool?
What is the clearance and what is the shim thickness used with the clearance?
del Sol si '94
Discussion Starter · #12 ·
Idk how he did it, its corrected now. Im leaving the trans building to the trans builders lol
<<<Someone didnt assemble the stack correctly...
Reactions: slo_eg8
1 - 12 of 12 Posts
