D16y8 5 speed hydro transmission.
Does it matter which way the input shaft bearing is facing?
Plastic ring up or down? Does it make a difference?
I'm mostly curious if one side of the bearing sticks out further than the other?
Context- the old input shaft bearing completely disintegrated. I took the old one out and put the new one in with the part number on the bottom side exactly how the one I took out was. After putting it all back together and sealing the case, there is slack in the input shaft. It moves around 1/16th of an inch in and out. As if there's too much space between the bearing and input shaft like the input shaft washers aren't thick enough?
Excuse my ignorance. I'm still new to working on transmissions.
