1 - 20 of 331 Posts
Acura TL-P
We are carrying the full line and offering the best pricing around.
PM ME FOR THE ABSOLUTE BEST PRICES AROUND!! WE WILL MATCH OR BEAT ANY ADVERTISED PRICE!!
We can even get the ones that aren't advertised, like the 88-91 SOHC kits :TU:
And the 95A inserts :TU:
Steel and Billet
Billet
Steel
Available in 60A, 75A, 85A and now 95a hardness on the inserts!!
Finish: Black Wrinkle Powdercoat Inserts: Red - 60A Shore Hardness Standard, Upgrade to Race or Track for $10 Extra.
The chemical engineering team at Innovative Mounts have formulated three general types of polyurethane bushings available in our motor mount kits.
This article will explain why we have the different options and how to choose the right one for your application. First, let's gain an understanding about the design of the OEM factory mounts.
Factory mounts are usually made of thin gauge metal stamped and partially inserted with a rubber material. The rubber usually has two or more sections that meet in the center to hold the center pin. These sections do not hold the motor firmly and are prone to break under sever driving conditions and/or when used in performance applications.
Innovative Mounts has engineered a unique polyurethane bushing unlike no other. Our bushings are solid, will never wear or break, and come with a life time unconditional warranty. A key design decision in our bushings is that it makes minimal physical contact with the mounting bracket or chassis. The shape of the urethane bushing is tapered to prevent binding between the chassis and/or mounting bracket. This allows the urethane to gradually absorb engine movement and vibration.
Doesn't Get Better Than This!
Weak Factory Design
Tapered Polyurethane Design
All of our bushings are designed in the same general shape. What varies next is the hardness or durometer rating of the urethane.
So how do you choose what stiffness you need for your application?
The 60A Red bushings are recommended for street cars. Most of our kits come standard with these bushings. They provide the least amout of vibration transfered from the engine to the chasis. This equates to a more comfortable everyday ride.
Our 75A Black bushings come standard on all H/F - Series engines. These engines weigh more and need a stronger bushing. We recommend 75A for street and track vehicles that make more than average horsepower. This rating of bushing is also for those that would like a stiffer feel and less engine flex.
Lastly, we provide 85A Grey bushings designed specifically for race cars or drivers that seek a solid engine mount kit.
UPDATE: 95A inserts are available, as well as solid billet mounts.
** Most orders will drop ship directly from Innovative. I do what I can to expedite all the orders, no matter what the size or cost is, I stay on top of them. There's more to it than just price, we also try to offer the BEST service :TU:
Acura TL-P
Bringing you another first from Innovative. :TU:
Kit comes complete with 3 mounts, custom rear bracket and cable to hydro conversion. MSRP is $349.99
This will allow you to bolt the 92-95 hydro transmission into the 88-91 chassis.
Once again, you saw it here first. :TU:
4 doors of fury!!!!
nice!!! its about time someone did this.
i like the billet mounts i may be interested in a set. GO Autoworks!!!!!!!!
WOW, very sexy. How much for the billet mounts and steel for 95 civic with d16.
Acura TL-P
whats a 88-91 sohc kit go for? in both the billet and steel?
88-91 Billets aren't available yet. The Steel kits areusually $195 shipped (which of coarse for you it would be a little different since your north of the border) I still have my 85A 88-91 Steel mounts up for sale in the For Sale section if you are interested in them.
Acura TL-P
Discussion Starter #20
Just got the most ballin' stealthy mounts I've ever seen in for a build we're doing.
Black anodized billet w/ black 75A inserts :TU:
1 - 20 of 331 Posts
