bracing does wonders....!
why do you think ssac was having their manifolds crack..... they were the same size(thickness) as header piping
and now it is still paper thin... but braced
bracing does wonders....!i'd be concerned about the strength of the header peice. it wasn't designed to carry the weight of a turbo.
but still, props for doing something different. hope it works for ya
-Luke
fo sho that's some sexy shitSomeone had there thinking cap on for that build....:TU:
same herei'd be concerned about the strength of the header peice. it wasn't designed to carry the weight of a turbo.
yup it sure will:beer:i wonder if a stock 2 peice mani would be able to hold up??
wrong link i think? Where could i get hold of the 2-1 collector for the exhaust inlet? That setup also needs new gaskets made as the original ones burnt through in a day!yup it sure will:beer:
http://www.d-series.org/forums/newreply.php?do=newreply&p=719990
i believe the car was bought pretty much stripped, and that was the motor put in due to budget...why is the d in an integra?
i tried reading most of that write up and i dont believe they said
EVO 8 turbo has seperate holes in the turbine housing and are both controled by the single internal gate.Hey Geoff, I have my old cast manifold... should be strong enough without any bracing. We could try it with that.
What about the wastegate(s)? You think we'd need two to completely separate the exhaust pulses? I have some ideas I'd like to try.
oh, thanks for helping with my suspension. feels MUCH better now.
yeah sometimes i suck at the intra web.wrong link i think?
