1 - 4 of 4 Posts
Im trying to setup the voltage conversions in Hondata SManager and I cant find any exact numbers. *I was wondering what everyone else was using
1992 Civic Si
Depends if you used the yellow wire or the brown wire, and depends if you've programmed it from factory defaults.
RTFM
The default analog outputs are as follows: Analog output one (yellow) is 0V =
7.35 AFR and 5V = 22.39 AFR. Analog out
put two (brown) is 1.1V = 14 AFR
and .1V = 15 AFR.
Discussion Starter · #4 ·
Another problem Im having is I have to constantly adjust the voltage offset in SManager to get the AFR to match. Could this be a problem with the ground on the LC-2? I've tried two different Hondata ecu's and the same thing keeps happening.
While on the subject. I cannot for the life of me to get the first column to be in range. It is always from 15 to 20% lean
1 - 4 of 4 Posts
