1 - 14 of 14 Posts
JDM Justin
95 del Sol
are you using them for the mods you have stated in your other thread?? if so yeah they will work, are you planning on any kind of tuning??
JDM Justin
95 del Sol
not really...n/a cars can benefit from larger injectors too...especially if they are built :TU:
JDM Justin
95 del Sol
if you do get the injectors...please prepare for chipping your ecu...after you get your head built, it will flow alot better...with the injectors it might richen up your fuel...so tuning is where you control that.
www.pgmfi.org <<--- AWESOME SITE
JDM Justin
95 del Sol
did you not read his other thread...guess not
93 cx hatch
Unless your going turbo they are a waste of money!!!
all i have is i/h/e/ and a cam... my shit was running at 90% i believe when i datalogged when tuning.....
anything more... or revving higher.. im going to need to upgrade....
310s should be more than enough for any build... but you could always just pick up dsm 390's or 450's for cheap
The Great Weldini
91 civic
i was looking in getting a set of 310cc injectors for my N/A setup. but i'm pnp my head, 272 cam, 11-12:1 comp, pm7 piston and itb's once my engine is broken in. but as for fuel pump i will be using a 190lph fuel pump. i feel anything bigger than that would be a waste. yes i do have a set of 450cc injectors right on my kitchen counter, just in case of who knows what. but i doubt i'll do anything w/them. lol.
Injectors flow rate varies in function of HPs... note in function of the way you get them, or barely, because of brake specific fuel consumption.
The function is the following:
Flow rate= (Hp x BSFC)/(number of injectors * maxcycle)
It is recommended to keep your maximum duty cycle under 80%, but I think the PM6 goes up to 91%, so it's probably not that bad.
If your injector seem barely too small, you can try raising your fuel pressure before to change injectors. Don't raise it too much on stock injectors, though, as it could alter their functioning.
With I/H/E and a cam I don't think you should need bigger injectors.
1 - 14 of 14 Posts
