Looking for some recommendations for injectors which are good for pump gas AND E85 with a flex fuel sensor. Power goals are around 500whp on E85. Tried Bosch 1300cc injectors - mapping on E85 was okay, but with pump gas (100octane) not possible to map :/
Any experiences with injectors for both gas options?
Tape-R taper/driver
EC3, ED8, ED9, EE5
What issues were you having? What tuning software?
A modern 1000cc+ injector should have small enough low pulse-widths to pull double duty.
Our shop CTS-V is running 1500cc injectors with Flex Fuel and it runs fine on gasoline, E85, and every mixture in between.
Its a 1350cc engine (modified d13b2) so i need a lot of fuel and more fuel pressure than stock. i'm running 1300cc injectors, but it isn't possible to map it on gasoline. e85 is okay.
Tape-R taper/driver
EC3, ED8, ED9, EE5
1300cc injectors will support 550-600whp on E85 @ 3bar base fuel pressure.
What base fuel pressure are you currently running?
