1 - 20 of 21 Posts
5psi of boost? why not just run stock z6 injectors...the motor would be able to run 8-10psi of boost of course depending on the turbo and tune
stock injectors wont hold 8-10 psi, you smoking crack homie:bong:
just pick up some 390-450 and be safe
I have a set of b series in there and I am only running 5 psi but all my co-workers say I will blow it, I have no problem with it.
Boost Gets You Laid
I think you missed the fact someone already said z6 and b-series injectors are the same.
Don't be a cheap ass, spend $50 and get some DSM 440ccs and do it correctly
they are the same as the stock z6 injectors...
and just buy some dsm 450s and call it a day.... theyre cheap and will hold over 300 whp
are you sure cause Im going to slap on my turbo kit on soon and is debating on getting some rc650 injectors or sticking with the bluetops that I already have just aiming for 250 to the wheel, will them 450 do the job?
1 - 20 of 21 Posts
