1 - 1 of 1 Posts
head gasket leaking
edit - cant change topic title apparently...injector issue fixed itself, just have to find the loose wire, having leaking issues now though
i just built a z6 and dropped it into a crx. i got a z6 full gasket kit and it came with a 3 layer metal head gasket. i got ARP head studs, put them into the block with the sealer they supplied, use an alan to tighten them down some because the middle ones didnt go down nearly as much as the end ones by doing it handtight as the instructions said to do. put everything on and torqued the nuts to 60 ft/lbs per spec. but now im getting oil leaking from all around the head. anyone experience any problems like this?
1 - 1 of 1 Posts
