1 - 9 of 9 Posts
1995 Civic Coupe'
i have a stock d16 with bolt ons like intake header exhaust yada yada and i got a set of RC engineering 270cc injectors and was wondering if i can use my stock fuel pressure regulator??? If no then what should i adjust the fuel pressure to? THANKS
why are u running higher then stock injectors? and ur stock fpr will be fine but u will prolly run rich with the stock ecu
90 CRX Si
They will. Actually, it will run ok though, my buddy has those same injectors in a stock A6 car. Only thing with those injectors is they are lean at idle for some reason (wideband checked)
1995 Civic Coupe'
im actually planning on gettin a new ECU, port n polishing the head, n new intake mani and 62 mm throttle body i was just wondering if everything will run fine when its stock b/c i already had the new injectors and my stock ones just died
See above...
I'd run stock injectors until your tuning session. Then right before the tune throw them on it there.
1 - 9 of 9 Posts
