1 - 20 of 29 Posts
As title states I'm hoping I can get. Better directive to where to start looking for my issue.
It's a 1998 civic lowered considerably on F&F coilovers with skunk2 adj. control arms.
Seemed good but wanted to verify the alignment and found out there is an issue somewhere. Something either bent or pushed is what I am told.
To describe it is with steering wheel straight- one side you would have the wheel 4 finger width on left of wheel 3width on right side.
And vice versa on other wheel.
Maybe the lower control arms bent? Suggestions?
Yeah, I tried that. They didn't really have a lot to say about it. They just said that it had something definitely wrong somewhere.
Wasn't sure if this was a scenario people had ran into frequently.
The shop like most in my area suddenly don't care once they see it is lowered.
could be a shitty camber kit too
Discussion Starter · #7 ·
Thanks for the suggestions. I will doh or check these, appears to be skunk2 camber kit, which appears to be set up to counter act whatever is busted as it is at the max adjustment currently
Discussion Starter · #8 ·
Never thought about spring perches though
pics also help. multiple eyes better than a single pair
Discussion Starter · #10 ·
I agree I will get some hopefully today
Discussion Starter · #12 ·
Lol don't think anything like that, clean title car and all core support looks original and unbent or damaged
ej8
clean title doesnt mean anything. Just means it wasnt reported.
But really take it to an alignment shop and get a print out. Post the print out and we can tell you what each one means and what part controls that.
Without that there isnt much we can do
Discussion Starter · #15 ·
Ok yeah I'm going to try to get it as soon as I can. Lol 2 different shops and both never thought to at least shoe where I was currently alignment wise. It's only funny because without wanting it checked I never would have guessed much was messed up
Discussion Starter · #18 ·
Yeah pics aren't best I will try to get more but yeah passenger side sticks out more
Discussion Starter · #19 ·
Here are maybe some better pics? Couple to show from top of fender and from whole front
Discussion Starter · #20 ·
Update to this topic,
Finally got some suspension stuff fixed and problem is better but not gone.
I did:
Both sides
Inner and outer tie rods
Lower ball joints-right side bad
CV axles
And fresh alignment
Driver front lower motor mount-bad
It is better but ended up at -1.1 driver camber
-1.7 passenger side camber in front
Everything else looked pretty good
Ideas on what else it may be?
1 - 20 of 29 Posts
