1 - 6 of 6 Posts
So i'm in the middle of swapping my intake manifold over to a z6 from a b7 and i noticed from the throttle body (i think it is the fasst idle valve) there is a hose connecting to the im on the b7 and there is no spot for it on the z6 so what do i do with it????? (pic attached)
also i will need a d16z6 intake manifold gasket for this right? my d15b7 one will not work?
help pleasse
thanks
d
Well?
thats wierd, the Z6 mani i had had that tube, but my B7 didnt and i had to block off my Z6 tube. The gaskets will work, but if you plan on taking it on and off more than once, get a re-useable one like a hondata gasket
1993 Cobra
I went through the same thing with my skunk2 manifold. Just get a T-fitting and plumb it into the main coolant line going into the manifold from the head.
1 - 6 of 6 Posts
