1 - 11 of 11 Posts
d-series smartass
alright, i've tried my best to get my shit working like it should, but i've had no luck. i chipped my ecu myself, the car ran like shit, i figured i must have done a bad chip job, despite it looking like it was done correctly. so, i order a chipped ecu w/ emulator from xenocron. still, the car either doesn't start or runs like shit. however, i plug the stock ecu in, and the car starts and idles great...
for now, i want to run uberdata. i've tried versions 1.6, 1.666, 1.7, 1.94... and get the same results. i've tried my own setups, usually too rich and the car smokes, and i've tried bins from fook, and other z6 setups, but never does the car run well. i don't want to run crome/crome pro until i have the cash for it, and i've spent sooo much already and haven't gotten anywhere. others have run uberdata, and i want to start with uberdata. i've driven it twice in six months of working on it.
here's my setup:
i have 240s in right now, but have 450s (correctinjects), i've swapped back and forth and can use either injector, so whatever i need to get the car to run.
stock d16z6/ ex tranny
hf manifold/ 14b turbo
cosmo fpr set at 42-45psi
new headgasket/ arp studs
3'' exhaust, 2.5'' dp
plx m300 wb o2
carsound hiflo cat
6'' fmic/ turboxs bov
moates ostrich/ chipped p28
brk7se-11 plugs
walbro 255lph fuel pump
rre catch can
if someone with tuning experience would offer me a few minutes of their time so i can call and brainstorm with them for a few minutes, that would be great. i'm sure i'm just missing something minor, and have no tuners near me to help me out. i've been running solo with no help since day 1. pm me if you can help me out, or post up any suggestions.
Correct Injectors from Tuner Toys are often faulty. This is why they stopped selling them. There is a good chance this could be your problem.
d-series smartass
right now i have the 240s in, i just can't create a decent basemap or something. i've followed your writeups, and usually the car will not start at all...
I have an ebay p08/p28 obd1 vtec/5000 redline/9000 RPT TURBO 8psi chip. I wouldnt trust the 8psi part but it should be a good basemap that would start the car if everything else was fine. I can read whats on it with my willem burner and email it to you if you want.
d-series smartass
ok, i made a basemap with crome on my xenocron chipped ecu, and it works. the car starts and idles. i went ahead and put the 450s back in as well.
my oil pressure is good, my temp is below normal, although my coolant sounds like it's bubbling after i shut the car off (possibly ANOTHER blown headgasket?) hopefully not, as this one only has 40 miles on it and the head has been milled and rebuilt... hard to tell at this point, but i'm not ruling it out.
i disabled my atmospheric pressure sensor (map?) and closed loop, reset the maps for 450s, and the car runs. if i ease on the throttle it boosts well, but if i hammer it, it hesitates and doesn't like that at all. i haven't run it past 5k rpms at 7psi, it stutters after that and i let off or shift. it may even be the turbo being the problem, as it was used... it spins and pulls boost, but if a seal is blown it could be puking all kinds of oil without me really knowing it.
d-series smartass
i'll regap the plugs and see what that does. i have them set at the stock 40 something...
Lifetime Awesome Member
'89 CRX HF
are you running a wideband? what are your AFRs when you hammer it? you could be rich causing you to bog.
id hate to see you give up on Uber so early. what write-up were you using and what version of Uber?
d-series smartass
i'm running a plxm300, i usually see 13.3ish when i'm pulling boost.... i used bigwig's writeup, and i used to have a word document from a thread you posted a while back, but can't find it. i've tried using uber 1.7 the most, and 1.94 a few times. i can get a decent chip burnt with crome, but i'm yet to figure out the emulator.
d-series smartass
i think i may say fuck it and go cromepro. i've had no problem running crome basemaps, and getting nothing with uber. suck though, cuz uber's free, and if i figured it out, cromepro would be a breeze. i enjoy a good learning experience, but this has sucked ass.
1 - 11 of 11 Posts
