1 - 20 of 27 Posts
I took the civic out a lil while ago to break it in a bit since I finally got my tag and tires, the round trip was about 5 miles and the temp guage never moved.
I also have a check engine light on
Im wondering if Im just paranoid about the temp guage or if I should look into the issue. any help would be nice:bigok:
huh?
a bit of both...my shit never runs hot, but im always worried that it is and my gauge is bust....let it idle for a while and see if it changes..
well I mean I kinda got on it a few times and thought the trip woulda heated it up enough to move the needle. tomorrow when the sun is up and it isnt raining Ill be sure to do that. I had a guy in a clean ek civic give me a thumbs up, I felt good
huh?
Its always nice when others appreciate yer stuff.
depending on how long is sat, 5 miles might not have been enough...
lol, espcially when its stock with a 4 inch ricer tip tucked under the rear bumper lol. I like having the power kick in after 3 k lol
i think it should have moved a little bit at least. check the cel.
exactly how do I check the cel? pics would be VERY helpful here.
also I noticed when I let off the throttle it dipped down a bit
98 Civic EX
to check the cel, you can goto an automotive store and they'll do it for free, or you can jump the wire harness and count the blinks
huh?
yeah, go to O'riellys and use their diagnostic tool...fo free!
just not in cali..:(
Formally known as SPONSOREDCRX
bwah ha ha ha ha
CRX
BMX bike
just jump the scs with a paper clip.
2p blue connector, pass side kick panel.
ok, I looked at the temp sensor, the plug to it is broken and will not stay connected to it, anybody have any ideas on how to rig it together?
I was thinking:
1)solder wire to the sensor
2) alligator clips on the sensor and wire
92 Civic Hatch
I was thinking:
Buy new sensor, have correct, good connection. Its not that expensive man, on a engine your breaking in, I especially would just get a new temp sensor, just for ease of mind my solder job isnt adding resistance to the cricuit giving me an increased innacurate reading. Just buy it man!
also, when breaking it in, i would be sure to drive it until it is warm and then some at least! you car needs the heat for correct metal expansion and oil clearances, and thats critical, especially for proper break in.
whats the sense in buying a new sensor when the plug is broken?
Discussion Starter #19
my bad, buy a new plug/connector then
ok, lets say Im broke until payday and I have to use this car to get to work daily. how do I rig it up to work for 5 days.....c'mon now, I know the logical thing to do would to buy new but I got no money, I need ghetto engineering that works
huh?
clean up the conection and solder it up for the few days..as a "temporary" fix...
1 - 20 of 27 Posts
