Hoping someone could share some insight on how to alter this region productively when using Neptune RTP.
The Help file is severely lacking in my opinion, and raises many questions, including the attitude of the author.
Anyway..
I've attached a JPG with the window in question.
"Ignition Dwell settings are for advanced users only. (Which are defined as) Please do not play with these settings if you don't understand what they're for. What use was this sentence, why not use this space to explain what it does.
The RPM Based Ignition Adjustments are adjustments applied to the ignition value based on RPM. At those RPM, those values are added to table ignition time + corrections.
Actual ignition = Table + ECT/IAT/TPS + Dwell + ????
Right?
RPM Based Dwell Control allows you to adjust the charge time of the coil by altering the cam angle at which the charge starts.
So at these RPM, the coil starts charging this many degrees before discharge event?
Battery Voltage Based Dwell Multiplier is the value based on battery voltage that is multiplied by the cam angle from the RPM Based Dwell Control to product the final dwell values.
This number is multiplied by the degrees of angle above to start the charging the coil? This definition slightly hinges on the one above. And I believe is incorrect
So at 2000 RPM at 12.5V = 20x25 = 500 degrees of charge advance? Doesn't make sense.
I need a way to alter the charge time of my coilpacks in a sensible manner.
Also curious if the RPM based ignition adjustments are still needed when using the CKF as the CKP
Last few attempts to converse with James have been rather unhelpful with his personality getting in the way of constructive understanding, or possibly improving the software, which could use improving.
I'm about to switch over to a standalone or Hondata for a more straight forward approach that supports COP, trigger wheels as well as better documentation. I don't recommend his product to others as a result of the various issues, although it works alright. I even tried the Demon 2 and RD1..
Hoping some of you folks could explain in better detail how you understand it.
Anyway..
Right?
