1 - 7 of 7 Posts
I tested the ignition coil in my car. based on Honda Manual, Primary Resistance should be 0.6 - 0.8 ohms and Secondary Winding Resistance should be 13,200 to 19,800 ohms. i tested mine and it was not in spec so i get a new one from dealer but this new one also give me same results as old one!
Primary Resistance:
Secondary Winding Resistance:
the result for new one was also very similar! am i testing it wrongly or what?
needs a D
why are you testing your coil? if you think you are having trouble with the distributor try the ignitor, and make sure all the wires are snug. also your tester might not be accurate.
x2 You beat me to it... Ignitor check it.. $80+ from the dealer too..
1 - 7 of 7 Posts
