OK guys i got a d16z6 running 6lbs on a GReddy emanagement system
first off it HAD a cel for a map sensor .....so today driving to work it did fine
when i engaged the clutch and let off the throttle is died
turned it over and it started up but shut right back off tryed it again and it ran but with a revving idle and the cel went away
any ideas i believe its the map sensor but im not positive need some helpfull input on this on
Well the thing is I runs fine when the cel comes on for it and it's not coming on . I'll try that to see what happen just started wasn't pushing it or anything
when the CEL comes on your ECU disregards the signal completely and so the signal has nothing to do with running the engine. however, it takes time for the ECU to conclude that the MAP sensor reading is not in line with what it expects. until that point, the ECU keeps reacting badly to bad signals being sent by the sensor.
