Ok first off i have a 1997 civic cx hb. i first put on a y8 mani, and when i did that i used the y7 throttle body and the y7 iacv sensor so all my plugs would go right in. got done car ran great no check engine.
then i got a y8 head i put the head on and wired up the vtec/knock/vtec pressure, and put in the p2p ecu. when i went to start it the car was only running on 3 cylinders. come to find out i had tightened the valves a little bit to much. once i got the car running right i threw a cel for o2 sensor probably because i toasted them when the car was running bad. with that said i drove the car and it ran fine. this is were one question comes in.
is my vtec working because i have a cel. it feals like it is but i cant really tell.
but anyways i was surprised the car would only redline at 6800, so i did some research and i guess some just do that. then i decided to get a p28 and a jumper. i ran the p28 and the car start surging from 1k to 2k in a perfect rythum. when i raced someone that usually beats me though i took them by a car this time.
now i think it is doing this because my iacv valve is a three wire and the p28 searches for two, however i though the ptp also searches for two. so why is this only happening on the p28. now what i wanted to do was put the p2p in for inspection time and still have the p28 run no problem when i go to race.
now im thinking maybe they make some vtec ecu's that search for the three wire and i just so happened to get a hold of one, and though one have a lower redline. but i just dont know. i dont want to wire it up for 2 wire if i can easily throw in my p2p, so that why i kinda stuck here.
so if anyone could enlighten me it would be greatly appreciated.
Live,love,laugh,be real
96' Accord Wagon
search is your friend, just go advance and make sure to only have it search the title or you will a bunch of crap...lol
i have searched so much and i usually always do but i just can find the answer. im hoping somebody here has had the same problem and knows a little more then me.
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
check all sensors? hooked up & completely snapped in?
ES1 Civic
i have a manual p2p, and if i had a vacuum leak the car would do the same thing with the manual p2p as it does with the p28.
