1 - 2 of 2 Posts
C
alright heres the problem when i start my car up in the morning it idles at 2200rpm.i can let it idle for up to 10 min and the idle wont drop at all.once i drive it,it drops to 500-600 rpm.ive adjusted the idle and it still does the same shit.sometimes the idle wont drop and i can put into 1st and the car drives at 10 miles an hour without touching the gas.any advice.
Mine did that and it went away as soon as I changed my tb out, so Im guessing its your TPS doing it.. Or maybe you just need to clean your IACV on back of manifold..
TB = Throttle Body
TPS= Throttle Position sensor
IACV= Idle Air control Valve.. IF you didnt know.. :)
1 - 2 of 2 Posts
