1 - 6 of 6 Posts
Hermit the Crab
So my CEL has come on a couple of times, I've tried to jump the ECU to pull the code myself but was not successful. I took my car to have the code read, the code is P0505 Idle Control System Malfunction. What do I do to resolve this? I did a little search and came across something about dealer saying I need to change my throttle body.:confused: But i'd rather ask you "GOD'S OF THE D-SERIES":) first!! Thanks for helpin' a :newbie:!!
Hermit the Crab
soundz like it does it lope at idle ?
Hermit the Crab
if you are able to jump your ecu do so and see what code you get. i got a code 14 before i did everything possible. cleaned iacv/tb. i think my problem was that i had some oil in my cylinders. so maybe check that out. also i had to just replace an o2 sensor. my CEL just went out by itself after i did those 2 things so idk what it is. goodluck though!
1 - 6 of 6 Posts
