1 - 11 of 11 Posts
well i have a d15b7 i just put a jrsc on it and now i have and idle issue its doing the yoyo idle thinggy
450 dsm
headers
intake
exhaust
ls ecu cromed
jrsc
d16a6 cam
stock block
and stock map
x2. It's running?
Is it oscillating around the normal idle range (600-700rpm)? Or wildly gyrating around? Almost dying, or revvin' high? Need a bit more info, too.
every time some one complains about the idle that mysteriously shows up they say they check vacuum but it is usually ~90%time a leak not from a hose. some times it the throttle gasket, injector seals, manifold gasket, or some other random gasket that was messed with. im going to guess its the injector seals from the 450s install
1 - 11 of 11 Posts
