1 - 17 of 17 Posts
ok i've been tryin to tune my car, got the wot ok,
but my idle is all messed up.
It actually was ok for a while, but the afr started becoming wavy,
bouncing from low 14's to high 15's slowly (afr curve looked like a sound wave on the datalogger).
When I first tuned it, it was fairly stable.
Then a few weeks ago it went completely off,
and jumped up to like 1500-2000 rpm, with crazy afr bouncing all over.
no CEL,
and when I put my stock ecu back in, it settles back to normal(so i know its not the idle valve)..
running crome free,
jdm d15b vtec..
ANY ADVICE!?!?!?
if you did not know, you can cut jumper in ecu to return back to stock bin and no read your eeprom.
no CEL,
if it's a tuning a issue. try to look at the stock ign and fuel tables on low cam, be around those values in your tuned bin and it should help, IF your motor is stock-ish. good luck.
edit: i meant stock values in idle cells
Discussion Starter · #8 ·
ok well this was pissing me off so i ran my stock ecu for a while.
just today I put the tuned ecu/ostrich back in, and the problem seems to have dissapeared!
I also reset my ignition timing, i think it was off a few degrees(though I don't see why that would cause an insanely high idle).
Perhaps all that was needed was for the ecu to be reset?
Those of you who tune a lot,
is it common practice to reset your ecu every now and then, or does it make little difference??
there is a short term and long term fuel adjustment table in the ecu
resetting the ecu will reset both of them
How would the fuel maps change and remain changed on the ecu??? Aren't they at a default setting from the factory? Or does your ecu actually learn how you drive and make adjustments?
89 Crx
what's an MIL?
as of now, i've been running my tuned ecu for about a week and the problem
is completely gone!
Something about swappin the stock ecu back in for a while, then going back to the tuned took care of it.
MIL=CEl Honda used to call the CEL an MIL back in Obd0 days.
And I use the removable jumper for J1 as well. its always a good trouble shooting tool.
d-series Member
im not sure but dont honda ecus use fuzzy logic? i forget, but if they do then yes the ecu would adapt some to your driving habits
1 - 17 of 17 Posts
