Motor: d16y7 with y7 head.
I downloaded and burned a .bin that I found on pgmfi.org from a nearly identical setup as mine to get the car running. It runs pretty good, but I would like to fiddle with the map a bit to see if I can get some better results out of the car. However, I noticed in Crome that their are a lo-and hi-cam maps in this .bin file. Being this is a non-vtec headed motor, which do I modify? I would assume low, but I figured I'd better ask before I screw something up.
Thanks.
yup just the low, disable vtec too.
just play with it you wont fuck anything up on a single pull unles you are changing the values by a large amount, little tweaking wont f anything up at all.
The H Badge is it!
91 crx
yeah what he said... if you add or subtract small amounts of timing or what not up top, it wont affect very much at all. i will say this though.. add 1 degree of timing up top and u will want more
Discussion Starter · #4 ·
Thanks guys,
Yeah, I'll try to be conservative. Dunno how long that will last.
