1 - 11 of 11 Posts
What mani would fit and clear?
I bought the turbo from one of my friends and he said it was a 16g. But he's not sure. So just checking on if it is. What do you guys think?
Thanks!
Looks like a small T3, could be a T25. Post the numbers off the tag on it, might be able to give you a better idea.
model number: TB0321
what else do you guys need?
Do you guys believe that with that right mani it'll clear a/c?
thanks again
It's a T3. You'll need the right mani and downpipe to clear AC.
Lurking... ಠ_ಠ In Your Thread
Ferio inspired
damn!, the wastegate actuator is almost as big as the compressor housing!:beer:
insert user title here
either a t25 or a small t3 .42/.48. like the compressor says. definitely not a 16g, not even close looking. very small
I'll probably ask autoworks to make a custom downpipe. What type of mani? I found a used one on ebay and he says it clears a/c. Its a log manifold and looks pretty good
t3, look at the bolt pattern coming off the exhaust housing
1 - 11 of 11 Posts
