1 - 6 of 6 Posts
hello all
i install my turbo now
but i have iat sensor like this
how can i pull it to the intake
cause if i will boost this will fly out..
Civic and Accord
just drill into your piping and jb weld it in, i did that and it holds good :) 1,5bar/22psi is no problem.
Hey guys I had this problem too, I found a quick and easy solution. What you need to do is drill a 7/8” hole with a step bit in the charge pipe near the throttle body and buy a plastic compression cord connector from a electrical supply store. They come with a lock nut, o ring and are oil resistant. The iat sensor fits right inside and once it is tightened it’s not slipping out.
Hey guys I had this problem too, I found a quick and easy solution. What you need to do is drill a 7/8” hole with a step bit in the charge pipe near the throttle body and buy a plastic compression cord connector from a electrical supply store. They come with a lock nut, o ring and are oil resistant. The iat sensor fits right inside and once it is tightened it’s not slipping out. - Jordan Robillard
1 - 6 of 6 Posts
