1 - 16 of 16 Posts
First of all sorry for my english.
Ok i want 500hp, i got a top mount manifold, d16 eagle rod vitara piston.
I want to know the perfect size of turbo?
and the best cam for this goal.
i would try to stay on pump gas. maybe water metanol if its impossible on pump gas.
let me know you opinion
thank you
make sure you have atleast 1000cc injectors and a good pump like a 400 or a 255 and a inline pump and good spark.
i have a sc50 and a bisi 2.4 cam and will be 500ish this spring. i ran out of spark and had a fuel prob around 417 whp. i have a 255 and stock ignition
i ran out of spark
No, you didn't. You may have an issue with your ignition system, but a properly working stock ignition should be fine at that level.
no
maybe water methanol kit if its impossible on pump gas
my friend run that on his 800hp rx7 and its perfect
I'm not sure what your saying here. A rotary is quite different. When you run out of water meth and you pop the engine, what are you going to do?
ok all my friend run water methanol kit
one on his rx7 and the other one on his b18 gt28r
and the other on his s2k
i am sure on me with this system
Well.......
1st I would like toThank god for this thing called the internet, and thank the creator of d-series for putting a search function for the site.......
With that said search this site for speedfactory's, big tuna's and a few other people build. Then google bisimotos build.
1 - 16 of 16 Posts
