1 - 11 of 11 Posts
i just fucked up my z6.... i messed up my main bearings and my rod bearings. i also bent a rod and the rod hit the block.... i have a d15b2 in my back yard but i was wondering, if i turn my z6 crank and get new bearings could i put them in to the b2 with no problems????? and would the displacement be same as the z6??? im not going to worry about the CPR since im going to drop new low compression pistons in it...
first of all. how did your main and rod bearings get fucked up?
2nd. do not "re-grind" your crank. if its bad then get a new crank.
so in all options of keep it pretty cheap. get a new motor
just get a new z6 block for like 100 bucks... i got mines for 50 bucks last time... common, it's just a sohc!! no need to waste time and rebuild it. after it blows, get another one!
FF Misfit
Accord
It won't work. The deck height of the 1.6 and 1.5 is different.
1 - 11 of 11 Posts
