1 - 11 of 11 Posts
Ive had this car for years and havent made one pull on it, one thing after another.
1.)I currently have a 374hp D16z6, I need new axles (again) and have 1994 Integra front brake calipers. Do I need need spindles or hubs to put these on?
2.)Are there any decently affordable higher performance axles?(300-500whp)
Thanks your positive feedback is appreciated.
:sign4: 11114730_912471472147731_3394214464187597224_n.jpg
D-series SoCal Division
93' dx hatchback
I would rather stick with the stock shafts, they're easier to replace then the gearbox. Learn how to preload from a dig.
When it comes to brakes, it all depends on what chassis you have. I'm gonna assume you have a '92-'95 civic. The calipers will fit if your rotors if they messure 10.3" in diameter (found in the EX models) Integra brakes are superior then those found on civics.
The long axle is two for two now. And I swear im not dogging the S41# out of it. I just dont know what to do. Really want it done for spring, so i can hurry up and paint her. The first (AXLE) one I bought the car I had to dig out and replace differential and internal gears. It was torture...
OK, will do. I already have some aftermarket traction bar for the apron towers, nothing name brand. First move will be with those bushings and motor mounts before I move onto the brake and axle predicament. Thanks again. >BeerDrinkin, cervan, AJAY, and slo_eG8. Will update if I ever get any of this done.
97 honda coupe
if your still dead set on getting a set of better axles, gator axles supposedly are really good. however your going to pay for that green magic.
1 - 11 of 11 Posts
