1 - 7 of 7 Posts
G
hey
i need a lsd i was reading up a bit on the different brands,
i basically need it for autox but the occasional drag.
setup
engine d16z6 with pm7 pistions
tranny ZC lsd ( but looking for somehting more aggressive)
what do you guys recommend?
thanks
hmm...try using a different tranny fluid...it may not be thick enough for ur lsd...use gear oil...i have the d15b lsd tranny...and my mechanic sed it will make a clicking noise if the fluid isnt thick enough...which can lead to damaging the lsd...
G
Discussion Starter · #5 ·
Go to general motors and get GM synchro mesh. put that in there. But first. Drain the transmisson then run a quart of cheap oil through it to clean it out. Put in the quart of cheap oil with the plug taken out. Then wait a few minutes after the oil is done draining. Then put the Synchro mesh in. The trans you have is great, mine doesn't chatter.
G
fuggen A, u wanna sell that bad boy? i'll buy it if it will bolt up to a 92 civic ..was that from a sohc zc? (mine is that with vtec)
· The Master Fabricator
Sounds like a Quaife might also be a good choice for you...
You already have a rare and very well reputed transmission.
If the tranny you have doesnt suit your application even after trying the different fluids, you could also sell it for around 500$ and then use the money for another lsd...
1 - 7 of 7 Posts
