1 - 15 of 15 Posts
Well. I put my itb's on and my stock d16z6 fuel rail and injectors and the fuel it to long the injectors will not fit . fyi these are going into the injector holes on the itb's , I am using a dpfi mani so there are no holes there. what should I do?
Your stock injectors should fit but you will need a bunch of washers inbetween the fuel rail and the manifold.. I think if you look the the ITB thread you will find a pic of what im talking about.
This is what i found in the ITB thread, its a post from Moose but the pics no longer work but he said "The Z6 injectors will fit in the CBR locations BUT the Z6 injectors are taller, so the fuel rail sits higher ... you have to use washers/spacers to allow you to bolt the fuel rail down"
dont space the cbr itb so u can use the cbr rail and z6 injectors, like stated above,
otherwise ud need custom spaced rails
I was saying that he can use the stock cbr fuel rail and why would you have to space the tb´s if it was made stock to use that fuel rail? The z6 injectors fit the cbr fuel rail because i have tested myself and have seen someone else do it also. Either im way out in space on this one or you guys are not really sure yourselves. I can go out and take a pic of z6 injectors in the cbr fuel rail for you guys and i will tell you if im wrong.
1 - 15 of 15 Posts
