1 - 10 of 10 Posts
91 CRX Si
Why cant you use the final drive out of a 88-91 DX/LX tranny? It also has a 3.888 final drive. Why must it be from a Dohc ZC? I'm just curious.
what is the differance from SI to dual cam ZC?? just curious. my friend told me to get the zc and put it in my Si tranny so it be a quiker gear ratio.
You need the ZC 3rd and 4th gears. The ZC final 3.88 will kill the performance of your Si tranny with a 4.25 final drive.
so i want the 3rd and 4th not the final. im new to this whole tranny thing??
OK, are you running or planning on running the ZC equal length axles?????
If not, swap the ZC 3-4 into a Si tranny, keeping the CRX 1-2-5 and FD.
If keeping the ZC tranny and special axles, drop in the Si FD and CRX 5th or a lower .702 if you desire lower crusing rpms. The ZC needs the revs within reason.
IMHO a CRX/Civic Si tranny with ZC 3-4 is the best. The left over parts from the ZC can be made into a 40mm DX tranny, good for those boost junkies to install a OBX into.
Define your setup, your racing style, your goals, your parts you have to work with, and your budget.
Yep. Here is a chart showing a stock Si and the hybrid S1/ZC/DX that I just built for my turbo car:
1 - 10 of 10 Posts
