81 - 84 of 84 Posts
Jdmaltezzacivic said:
My timing is at 17 deg. And my cam gear is at 0. Also now my ecu is throwing 4 check engine codes. Knock sensor failure. Miss Fire Cylinder 1,2,3. And this is only since the valve adjust to what builthatch had suggested from crower 4 intake 6 exhaust. Any suggestions builthatch whats going on there. Is my knock sensor really bad or is it because of the stage 3 cams lope. My car does not sound like it is miss firing and it runs really strong. And yes i know i need to get my car on a dyno i just have not saved up the money yet to do that also because my engine build is not done.
Set your timing to 10deg and see how it acts.
allwheeldriveturboboxer
'08 Mazdaspeed3
Discussion Starter #82
i would reset the ecu and put your timing @ 10 like jam said to see if it'll keep the codes from coming back. You need to make sure that the lash was done 4/6 without too much drag on the feeler. maybe try 6 and 8 again just to see if the codes come back, along with the retarded timing
S
this sounds like a good cam, should i run this cam or should i get the zex 59300 stage 2. im likeing the zex i deal becaus i can get that cam and springs for the price i would pay for the crower
ridin on rotas
you ever heard the saying "you get what you pay for". it would probably be worth it for you to save up for the crower stg 3
81 - 84 of 84 Posts
