1 - 14 of 14 Posts
idle 1.5 k
there is a vacuum leak at the throttle body
i sprayed carb cleaner at it continously and the car dies
i have changed the gasket several times same problem i have put liquid gasket
between the gasket and the throttle body same problem
i don't know what to do ?
peterbilt
is the screw in all the way
'91 CRX Si
leaking in through a crack?
or maybe through the idle adjustment screw?
peterbilt
go to junkyard get new tb or i see emon here fs for like 10bux hell i got a obd0 b16 tb laying around
what type TB?
d16z6 engine
leaks at the TB?
yes at tb
how are you spraying the carb cleaner?
i spray it all the way aorund the tb when i reach the area under the butter fly engine sound change and idle down when i spray it continiously in this are engine shut off
did you already clean the IACV and the TB housing?
cleaned iacv and the tb housing
no codes, right?
no codes
2005 Legacy GT
was just going to say fitv, take a look at it, unless you dont have one
I thought all z6's had FITV. OP you might also check that the FITV is functioning properly.
See above...
Maybe try a thicker, thermal gasket. It might fill in any gaps that a normal paper gasket wouldn't cover.
sorry about my english
first of all i have blocked the fitv because it always sucks air and now it doesn't suck any air the only thing that sucks air is the iacv it sucks alot when i put half my finger in the niple at the tp the car idle fine (full finger engine shut off)
i have tried a good known iacv from a running d16z6 and the same problem i have tried mine on that running engine idle fine so i have tried the carb cleaner and found the leak under the butter fly have made a gasket to the fitv and it doesn't suck any air
there is a broken area in my intake manifold where the tb installed
can this cause any vacuum leak
this intake manifold is not mine
Chevy with a cummins
look at the back of the tb and see how it matches up to the broken spot. very well could be the problem. get someone to weld it up or try another manifold. DON"T use JB weld it can break off and go thru the motor.
1 - 14 of 14 Posts
