1 - 3 of 3 Posts
On my turbo setup im gonna use a td04l subaru turbo. I have already ported the exhaust inlet and planned on mating a t25 comp wheel and housing to it to increase the cfm. Im also looking at a tdo5 turbo from an imprezza, (267bhp model) 20g i think??? what bits can i mix and match for the best setup?
what are your hp goals?
maybe just buying 1 turbo that is perfect for your needs is going to be cheaper than 2 or 3 just to get the parts you want then the price to get it rebalanced.
im aiming for 200bhp. i can get a t25 cold side for free so i thought i might as well bolt it on if it will make some noticeable gains. if the shaft is removed and put back would the turbo require balancing?
1 - 3 of 3 Posts
