1 - 12 of 12 Posts
I've been reading a lot about these turbos and I can't make up my mind about either one. My tuner is telling me that the hy35 will spool later than the 57 trim. The hy I have is a 7 blade wheel with 4 inch vband exhaust. I'm looking to make about 350-400 hopefully. I would like the turbo to be somewhat responsive at a lower rpm. Reason I'm asking is because I can get a 57 for really cheap from someone but won't if the hy will be good.
Setup will be,
Ported z6 head
Zex/comp 59300 cam
Skunk 2 intake mani
Skunk 2 valve springs and retainers
Block
Eagle/cp 9:1
Ive ridden/driven the pump gas 400whp HY35, and fyi this is a high altitude car at 4800'. Its sooo much fun. The power comes on late, but when it comes on its savage. Check out his thread previously posted. He put a dyno sheet up. The best part is all the compressor wheel silencer is removed, so its nice and loud.
If you have the HY run it. Theres a guy that just made 400 on pump with a hy:http://www.d-series.org/forums/showcase/168014-4-dr-sleeper-build.html
My precision was big on my stock d15 but who cares? It fuckin moved when it spooled up and got good gas mileage when it didnt.
Just took a look at the thread. It gives me hope! Shits a beast haha
Thanks. I think I'll stick with the hy then. I think I might have the older model 4 inch vband outlet hy.
Hp is just a number track time and trap speeds are cooler. i love holsets theyre cheap and readily available but as you said your useable powerband will be smaller.
The holset doesnt make the type of power that a 57 trim can make. Not even close. Wider power band with the 57. More peak power. Quicker spool. Better better better better. Lighter. Smaller. Quicker. Quieter. More efficient. Better.
I had a 57 trim on my car before the holset and I like the holset better. If you want low rpm response you need to look at other turbos. The holset pulls like a train and loves higher boost, mines at 21-22 right now. And with your build you can rev the motor higher 7500-8 and the hy will love that and you can still have a decent power band, I am only reving to 7200.
For the money its awesome, I mean yes I would love a GTX or some ball bearing but I don't want to spend that money right now. And yea the spool sound of the holset is AMAZING
I would say leave the holset in the wrecking yard ...so I can salvage it!
I've had a garret 57 trim and an hx35 on my street driven car , it will be too fast for the street with either... if the 57 trim is an actual garret use that.
If you look at the compressor maps, the 57 trim flows more air everywhere that a gasoline 1.6L can take it.
Trust me... track results and trial and error over butt dyno and self gratification and re-assurance.
Well the turbo I can get is the turbonetics t3/to4 57 trim for the price of $280. I bought this Holset years ago for the build when everyone was using them. I started get back into it recently with the build and all, my tuner/builder/friend is saying that the powerband will be kind of late with the hy and recommended a 57 of some sort. I'm not really good at reading or understanding compressor maps. A lot of people are actually telling me to get a 57, one of my buddies is running the hx35 and he actually loves it.
1 - 12 of 12 Posts
