1 - 12 of 12 Posts
My Civic
I was wondering where i can get a oil feed adapter for my HX35, i'm using a egay feed line, any help would be appropriated.
1990 civic 4 door LX
I used a steel -4 to -3 and put a crush washer on it. Had an aluminium fitting but it was weak and since threada were jlperfect it didn't work. I would rec what dan said. I just had to Do that for a few months
Mine had the stock brass fitting already on the turbo....I did a 5 sec Google search that gave me the size.....I eBay'd it up and got it in a week or so....don't remember the size but 12x1.5 sounds right
nope here is a link to the guy i bought mine from and the same peice i bought....
m16x1.5
C1 Fitting M16x1.5mm to 4AN Straight Fitting Adapter | eBay
again i will state i had the factory brass feed line fitting in my hx35 and this was the adapter i used with the stock fitting
also to get mine to clear my mani i had to use this then a 4an to 4an 90* elbo then a 4an to 3an adapter to my 3an feed line
mine still had the stock fitting...kinda hard to see
then the fitting i linked above to -an sizes
op post pics and do you have a hx35 or do you have a holset similer....hy35, h1c, HE35
1 - 12 of 12 Posts
