will hx wheels fit a del sol Si since it comes with the 4 disk brakes??? or will I need to buy some spacers??
either you've never actually put HX wheels on a civic, or you've never seen an EX trim one. i bought my HX wheels from a guy that used them on his type-r swapped 98 EX. he had to use spacers on the front. my 93 EX needed the spacers too. my 93 Si does not.never had a problem fitting HX wheels on ANY 92-00 Civic...
I was waiting for some one to say that I personally have Si del sol rims on my EF14's came on the Si, so you shouldnt have any problem fitting them on.
Thanks man, you dont need spacers, you dont need to shave the caliper down, just put on and go :TU:.^^ there ya go. now thats clean
:IHI: ,although you cant go wrong with the stockies also14's FTMFW!!!
funny because I have to have spacers on mine, or they wouldnt fit. 95 civic ex, bigger brakes, and have to get a spacers or grind it down some. Either you havent worked with larger brakes, or you just thought the fitment issue could be solved with just tightening them down harder.never had a problem fitting HX wheels on ANY 92-00 Civic...
