C
i heard that webcam ,crespo,hks,jun have made good cams for zc dohc
what are their duration and lifts?
which is the best?
i want acceptable idle also
thanks thanks thanks again
i've heard good things from delta cams, and crespo, go stage 2, anything higher your going to have a rough idle. don't go web i heard they sent out shitty cams. and numerous horror stories, as for jun or hks, if you can actually find a set, in good condition, kudos to you. cause that'd be a hell of find and a hell of a price tag
C
thanks all
slebidia said:
Rocket does a ZC regrind.
how does regrind on stock cam works?
will decrease cam lift while increasing the duration?
C
slebidia said:
Increase lift and duration by changing the base circle.
Here's a pick of my Isky cams. The no lift area of the cam you see there used to be the same height as the journal.
thanks
i never heard of this in hong kong
so i don't unstandstanf how to regrind on stock cam
regrind on my stock cam will be similar to buying a racing cam from the shop?
since the boss can custom made by regrinding for me
thanks again
C
how they can change the duration and cam lift of the used stock cam?
?_?
it is possible to made a higher cam lift and duration from a stock cam???
C
custom made cam for dohc zc by grinding.Is this workable?
NIPPON RACING PERFORMANCE STAGE 2 DOHC ZC CAMSAHFTS
JDM DOHC ZC HONDA CIVIC CAMSHAFTS
NIPPON RACING STAGE 2 CAMSHAFTS
GREAT MID AND TOP END WITH SLIGHT LUMPY IDLE
STAGE 2 CAMSAHFTS MAKE GOOD POWER BETWEEN 3500-7500
IF YOU WOULD LIKE i cAN GRIND YOUR CAMS TO EITHER STAGE 1, 2 OR 3 SPEC
EMAIL ME FOR DETIALS
VERY HARD TO GET CAMS DUE TO LACK OF GOOD CORES IN THE STATES
LOBE CENTERS HAVE BEEN MOVED TO 110 ON THE INTAKE AND 104 ON THE EXHAUST
MADE TO FIT OBD0 STYLE DOHC ZC MOTORS
is that true?
