1 - 20 of 24 Posts
After 12 years of being a d-series loyalist, I decided to swap in a b-series after catastrophe struck. I had an NA d16z6 that was making 158whp and 116wtrq. Now I have a garage full of parts that I need to sell. The parts come off a 1993 del Sol. The car was and still is barely driven.
I'm located in the Toronto, Ontario Canada area. If you're local you can either stop by to pick up the parts or we can potentially meet in the Great Toronto Area. I'm also willing to ship at additional cost.
Contact me via PM.
Exhaust
Meagan Racing 4-2-1 header: $200.00
- welded to a Magnaflow High-Flow catalytic converter with a 2.25" inlet and outlet pipe
- barely used
- 4-2-1 design is good for low RPM torque
- collector welded to the cat to reduce gapping
1320 4-1 header with 2.5" reverse megaphone collector $400
- used once when tuning the car and once for some open lapping
- practically BRAND NEW
- 4-1 design is gear for high RPM horsepower
Stock d16z6 header: $20
Tanabe Medalion cat-back exhaust (2.25") for '92-'97 Honda Civic del Sol: $550
- barely used
- incredible condition
- beautiful sound and fantastic build quality
- retails for over $700 Canadian
Head:
Stock d16z6 head with level 2 Bisimoto camshaft - SOLD
Rocket Motorsports level 4 d16z6 camshaft: $300
- used once when tuning and once on the track
- incredible power increase in VTEC
- with P29 block made 158whp
- retails for over $500
Rocket Motorsports valve springs and titanium retainers - $200
- brought redline on z6 motor to 8500rpm
- retails for over $300
AEM adjustable camshaft gear: $100
ARP d16z6 head bolts: $100
Black HONDA d16 valve cover: $20
Wrinkle Red 1.6L HONDA SOHC VTEC valve cover: SOLD
D16 NGK wires: $50
- barely used, like new condition
Intake:
Skunk2 Pro Series Intake Manifold (black): $250
OBX plastic intake manifold gasket with enlarged ports: SOLD
D16y8 intake manifold with inlet ported to 60mm and enlarged runner openings: SOLD
- professionally done at Canadian Cylinder Head
- was part of a d16z6 NA build that made 158whp
- d16y8 intake manifold is considered the "Type-R" intake manifold for d-series engines
D16y8 intake manifold with inlet ported to 60mm: $100
- done by me
- was part of a d16z6 NA build that made 156whp
Stock d16z6 intake manifold: $80
B18 60mm throttle body for d16 with FITV block off plate: SOLD
B18 60mm throttle body: SOLD
B18 60mm throttle body: $20
D16z6 56mm throttle body: $20
Block:
King Race Bearings: $50
- new in box
NPR 75mm P29 rings: $50
- new in box
11.4lbs Competition Clutch flywheel: SOLD
ARP flywheel bolts: SOLD
D16y8 OEM flywheel: $20
D16y8 professionally ported oil pump: $250
- brand new OEM Honda oil pump was shipped to California and professionally ported and rebuilt by Cole Mulvey of Bad Guys Worldwide
D16y8 cap and rotor - $50
- brand new in packages
- never used
D16 oil pan: $20
- good for oil line connection when building a turbo d-series
Transmission/Drivetrain
Stock d16 transmission: $100
- S40A000
Exedy Pro clutch: SOLD
- very few kilometres
Exedy Pro clutch: $100
- brand new and unused
- came installed brand new in d16y8 that I decided not to swap
D16 axles: $100
Miscellaneous:
D16 OEM radiator: $50
D16 alternator: $50
D16 starter: $50
Fuel rail with pressure regulator: $50
D16/D17 Stroker parts (in a bin): $100
- had plan to build a d16/d17 at one time
- bin is full of the rods, pistons and other components necessary to complete the build
JDM del Sol instrument cluster: $100
P28 ECU: SOLD
what is wrong with the head? I was so tempted on jumping on it
Which head? There's the stock d16z6 with the Bisi cam which is perfectly fine. The other built head was the victim of a dropped valve. The combustion chamber was severely damaged and unsalvageable. The Rocket Motorsports stage 4 camshaft, springs and Ti retainers are untouched, as is the AEM cam-gear.
Reactions: slo_eg8
ah, I see. not as excited as I was, but Im still looking to get some things. let me argue with myself
Discussion Starter · #5 ·
Sounds good.
I'll post some pics of the head of you'd like.
Not gonna lie.... this breaks my heart a little. I spent years learning everything I could about building the mighty D and now it feels like the end of the chapter. DSO has been by far the most important site in terms of research, and not just for the motor and transmission. My brake upgrade and suspension build were the result of DSO member contributions.
Reactions: slo_eg8
P28 ECU and wrinkle red valve cover are sold
Discussion Starter · #7 ·
Exedy clutch sold.
Competition Clutch flywheel sold.
D16Y8 intake manifold ported to 60mm sold.
B18 throttle body sold (x2).
Discussion Starter · #8 ·
Megan Racing 4-2-1 header sold
Rocket Motorsports valve spring, Ti retainers and keepers sold
D16y8 60mm intake manifold sold
B18 60mm throttle body sold
ARP head bolts sold
Black valve cover sold
Discussion Starter · #9 ·
Bump!
Been a while since I moved his up.
Parts are still for sale!
The Great Weldini
91 civic
whats wrong with this thread? no pictures.
do you have pics of the stroker kit and the 1320 header?
Discussion Starter · #11 ·
The Great Weldini
91 civic
Discussion Starter · #14 ·
Tanabe exhaust has been sold.
Discussion Starter · #15 ·
Skunk2 intake manifold and King race bearings are sold.
Discussion Starter · #17 ·
Rocket Motorsports stage-4 d16z6 camshaft SOLD!! To the gentleman with the pointy blue shoes!
Good luck with your build Louie!
Discussion Starter · #18 · (Edited)
JDM del Sol gauge cluster sold.
Discussion Starter · #19 ·
Axles and Exedy clutch have been sold.
Discussion Starter · #20 ·
Bad Guys ported new OEM y8 oil pump sold.
1 - 20 of 24 Posts
