ok im looking for some ware on the net that sells ht leads for my sohc 1.6 d series, after some performance one that will last a while and not die with in a yr if any one can help then please do
for the most of us on the OTHER side of the pond, he means spark plugs wires.
MSD, Magnacore, or NGK.
'91 CRX Si
NGK gets my vote!!!
Here's what TPRmag.com had to say about them:
The NGK wires had the best fit at both the distributor and spark plug end. The NGK wires were also the only wires tested with a factory outside diameter to fit in the OEW wire looms.
This is comparing them to MSD, Vitek, Accel, OEM Honda, Magnecor and Moroso
http://www.tprmag.com/issue/4/ngk.shtml
