1 - 16 of 16 Posts
12 point 10mm i believe around the pressure plate. remove pressure plate and clutch disc. then to reinstall on the other motor use an alignment tool to hold the disk in place. reinstall pressure plate and torque to spec.
nothing
yeah find a way to hold that crank pulley bolt and pull the pressure plate bolts off and SHAZAAM!
make sure to use some loctite on those pressure plate bolts when putting the new clutch on... just a little bit of insurance :bigok:
98 Civic CX-T on E85
Put one of the tranny bolts back in and use a pry bar to hold the flywheel in place. You can have an assistant hold it or rig up a setup like I did in this pic.
great idea never thought of that...but i use air tools so no need i guess
one grumpy old man
or cut a lil piece of flat bar and drill a hole in it so you can put it between the bolt hole and the flywheel.
No Tune No Life!
99 Supercharge Regal
Im having trouble taking off my d16y8 clutch. i got my tranny off and now i need the clutch off to put on my d15b motor. Help?
Pm or call me asap 416 270 0143
These guys are willing to help you but word of the wise dont post a clutch question in ENGINE MANAGEMENT!!!! and DONT POST YOU PHONE NUMBER thats how bad things happen. lol
some one relocate this to Transmission Alley.
if you post in the right spot people will be more willing to help.
'95 DX Coupe (Red)
Not sure how safe the oem jack is with the cinderblock, but hey- you're still alive!
the oem jack is designed for lifting the corner of the car for short periods, so holding part of the engine it should be fine, probly only about 100 to 150lbs at most on it... i have done this before, but when i had spare $$$ i bought a second cheap hydraulic jack for this... sometimes you have to make do with what you have...
jb weld fixes all your engine and trans problems ;')
sloopy.
1 - 16 of 16 Posts
