Hello guys, I was wondering if anyone has a easy way to tell me how to replace the fuel pump in my 96 ex.... I know its under the plate beneath the back seat... but thats about it.... Thanks!
honda/firebird form.
take out seats, remove plate, take out fuel pump, install new one, replace plate, replace seats... its really that easy lol
Poop Sock
wrx & slut rex
if u got a walbro they come with instructions. it's easy and only takes 10minutes. u just gotta get in there. oh and disconnect the battery first
95 ex coupe
yup very easy. you should have no problem getting it done.
takin the seats out and puttin them back it will most likely take longer
ok, make sure you un hook the fuel filter lines, or when you unplug your return and feed line you will soak the interior in gas. un hook the battery, get a special wrench (cant figure out the name of it right now, but its a special wrench for fittings like the solid line on the filter" loosen in, then remove rear seat, unscrew 4 phillips heads, unclamp the feed and return line and unbolt the 8 bolts holding the filter in. wiggle and twist on the pull ouit and done
btw, the warranty is void if you dont drain the tank *
