1 - 2 of 2 Posts
I used a flat-head screwdriver and started at the rear. Carefully pry up working your way towards the front. They will get bent out of shape a bit (how much depends on how careful you are), but they can be re-shaped easily enough when you go to re-install them. Also, I practiced removing one on a car at the junk yard which helped.
1 - 2 of 2 Posts
