1 - 7 of 7 Posts
Acording to the info i gather from this threads:
http://www.d-series.org/forums/engine-building/100139-diy-main-bearings-rod-bearings.html
Civic EG :: View topic - How to determine Bearing size (Main & Rod)
This is the info i got from my block and crank:
Crank Bore Code Location (Casting Letters on the block by the flywheel) are as follow: DCBBB
D being 1st journal- last B being 5th journal.
Info of the number casting on the crank from 1st-5th journal.
1=2
2=2
3=3
4=3
5=3
Now the color of the bearings from (1st main journal-5th journal)
1=Brown
2=Green
3=Green
4=Green
5=Green
So i have to order acording to the info i got:
1st main= 2 Brown
2nd main= 2 Green
3rd main = 3 Green
4th main= 3 Green
5th main= 3 Green
(1) 2 Brown
(1) 2 Green
(3) 3 Green
Now how do i order them, what part number are they? im planing on order them from hondapartsunlimited or majestic honda but dont know how.
PS- I only got the main bearings besides im gonna be using after market rods.
honda/firebird form.
you give honda the bearing color and number.. thats how you order them.. but from reading the other threads, they were out of the brown bearing or discontiued them..
92 civic cx hatch
you will just call up honda and tell him your motor and tell him how many greens which seems to be 8 greens and 2 browns, the column doesnt matter weather its column 2/3/4/5 etc, the greens and same with the browns are all the same thickness its just a guide to the next color witch will be tighter or looser
from what i heard honda store has all the bearings available from what i heard.
Im only ordering for the main bearings keep that in mind. So know one can provided me the part number for the berings acording to the online store that i mention in the post.
too many
The colors are listed in the link above.
13211-PG6-003 019 008 BEARING A, CONNECTING ROD (BLUE) (DAIDO) 12.77 8.94 Qty:
13212-PG6-003 019 008 BEARING B, CONNECTING ROD (BLACK) (DAIDO) 12.77 8.94 Qty:
13213-PG6-003 019 008 BEARING C, CONNECTING ROD (BROWN) (DAIDO) 12.77 8.94 Qty:
13214-PG6-003 019 008 BEARING D, CONNECTING ROD (GREEN) (DAIDO) 12.77 8.94 Qty:
13215-PG6-003 019 008 BEARING E, CONNECTING ROD (YELLOW) (DAIDO) 12.77 8.94 Qty:
13216-PG6-003 019 008 BEARING F, CONNECTING ROD (PINK) (DAIDO) 12.77 8.94 Qty:
13217-PG6-003 019 008 BEARING G, CONNECTING ROD (RED) (DAIDO) 12.77 8.94 Qty:
13321-PH3-004 020 010 BEARING A, MAIN (BLUE) (TAIHO) 13.22 9.25 Qty:
13322-PH3-004 020 010 BEARING B, MAIN (BLACK) (TAIHO) 13.22 9.25 Qty:
13323-PH3-004 020 010 BEARING C, MAIN (BROWN) (TAIHO) 13.22 9.25 Qty:
13324-PH3-004 020 010 BEARING D, MAIN (GREEN) (TAIHO) 13.22 9.25 Qty:
13325-PH3-004 020 010 BEARING E, MAIN (YELLOW) (TAIHO) 13.22 9.25 Qty:
13326-PH3-004 020 010 BEARING F, MAIN (PINK) (TAIHO) 13.22 9.25 Qty:
13327-PH3-004 020 010 BEARING G, MAIN (RED) (TAIHO) 13.22 9.25 Qty:
1 - 7 of 7 Posts
